speedyink VIP Member Sep 19, 2006 #1 Isn't DDR3200 supposed to go twice that speed? Last edited: Sep 19, 2006
StrangleHold Moderator Staff member Sep 19, 2006 #2 Thats the CPU tab, pc3200 is DDR400, runs at 200 double data rate=400 Last edited: Sep 19, 2006
StrangleHold Moderator Staff member Sep 19, 2006 #4 unless you have clocked it down to 166. If its running at 200 its right!
speedyink VIP Member Sep 19, 2006 #5 Isn't it supposed to run at 400mhz? Or Does CPU-Z mean 200mhz x 2(ddr)
Motoxrdude Active Member Sep 19, 2006 #6 speedyink said: Isn't it supposed to run at 400mhz? Or Does CPU-Z mean 200mhz x 2(ddr) Click to expand... Precisly
Motoxrdude Active Member Sep 20, 2006 #8 Yuep, no problem. The actual frequency is 200mhz, but the effective frequency is 400. Same goes with video cards and there memory speeds.
