For the mentally impaired it's like this.Shouldn't talk to yourself there now!![]()
{quote=SirKenin]You download the file to your harddrive. Put it in an accessible directory.
You boot the Recovery Console with the CD.
You log on to Windows.
You access the file.
You execute it.
That wasn't so hard now was it?![]()
Once you boot with the installation disk you wouldn't even be using fdisk. You simply use the fixmbr command for the mbr itself. Fixboot is the command used to repair the boot sector. For the actual list of commands used at the recovery console Microsoft will gladly provide you with that at http://support.microsoft.com/kb/314058go back to sleep!
