Paint, Wordpad, Calculator and Etc.
cyclones9
Does anyone know where i can find the Paint, Wordpad and the Calculator shortcuts? Somehow they got deleated from my start menu and now it can find the link. Thanks
C:\Windows\System32
Search around a little bit, they will be called things like paint.exe, wordpad.exe, etc. Right click on the file and "send to desktop" or "create shortcut" or whatever option you have.
edit: the filenames are calc.exe, write.exe, and I can't find the Paint file right now, but it is somewhere in there
Re:
Ok.. Thanks.. Do u know where the shortcut is for Internet Explorer? I looked under Program Files but theres nothing there...
* Im not seeing anything under the System 32 fldr. for the paint and stuff.. N e way to Redownload them?
Start > Search > Type in: iexplorer
Well my IE is in Program Files, under a folder called Internet Explorer
As to downloading the files....I googled a little bit but didn't find much of anything. Look on Microsoft's site.
Also, you might be able to find the files on your Windows CD.
