Motoxrdude
Hey, i just got my x2 3800+. When I put both cores under full load my CPU temp rises to 50C and core rises to 50C as well. Is this normal and safe? I am using the stock cooler btw.
It's safe as long as it's under 65°C, are you using a stock HSF? 50°C isn't bad but it's a tad high for stock voltages.
Are you using the stock heatsink and thermal compound?
