cyberpower pc
can some PLEASE if not much trouble show me a build or lead me in that right direaction for a cyberpower pc 15.4'' widescreen perferably hellfire cover and under 1900 for total and cpu like centrino or amd i just need sum help
http://www.cyberpowerpc.com/r05/ri05.asp
The intel core duo would kick the crap out of the amd's though.
http://www.cyberpowerpc.com/system/ntbkx56800.asp?v=d
"a cpu like centrino or amd" seems to be what is being looked for there.
i might go back to the dell
i had a 17'' widescreen 1gb ram 100gb hdd for like 1800 i have to limit at cyberpower
Yes, but he wanted flames and he asked us to lead him in the right direction. Anyways centrino is not a cpu. Though that amd one would be the one I would get if I were going amd.
And where there does it say that centrino is a CPU? Centrino is what intel calls its bundle of laptop CPU, motherboard/chipset, and wirelesss adaptor.
http://www.cyberpowerpc.com/r05/ri05.asp Look at the model on the right to see where the Intel® Centrino® Duo Mobile Technology is not a bundle. For other details, http://www.intel.com/products/centrino/duo/description.htm
For the AMD line of mobile cpus it is called Turion™ 64 Mobile Technology.
http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_12651,00.html
It's not a CPU. There's no denying that, you can think whatever you want, but it's not. Centrino is a three-part system for intel laptops.
It doesn't matter what I think. I'm not the one you have to bring this up with. :P
I may be mistaken.. but isnt Centrino also the grafic's processor of the laptop? ( dont hit me if im wrong on that, but i never had a laptop with that yet)
Centrino IS NOT a processor, it is what Intel calls their laptops that have the Intel Pro wireless, Intel chipset, and a Pentium M/Core processor.
If you look, they call laptops Centrino for Pentium M's, Core Solo, Core Duo, and Core 2 Duo.
34erd is correct.
34erd is correct.
You could always ask the poster what he meant when referring to "cpu like centrino or amd".
