Microsoft Windows XP media Center Edition...
djcon
Has anyone had any problems with this OS? I've found that it crashes alot, and the onyl diff is that it has another program... Should I try and get XP Prof? or Home? or is it something simple to fix?
thanks.
DJ CON
Depends if you really need media center
its nothing special to me, but ive never noticed any problems with it for the past 10 months
it on my media center playing some lovely Chopin (Nocturne) as we speak :P
It does crash quite often probably once a week, thats with it running 24/7. The hdd is totally full and i find it quite slow sometimes.
If you dont need MCE then dont get it
ok thanks... i think i might switch to prof. See if it works better... Thanks for the input all...
My friend has Media Centre and sometimes had problems getting games to run.
Dont know why:rolleyes:
