I am looking for a gaming case to show of to my friends, is this one good?
Buy a cheap case and mod the crap out of that, then its really flashy and original. Its not just a case with a window and led fans like most pre-modded.
You will get tons of ppl telling you which one you THEY like and not the ones you like so.. why dont you tell us more about what you are looking for. Is it a cheap but flashy and good case or just anything that is thrown at you?
Well, I want one that will really grab attention, but at the same time won't break the bank. Good air flow would be nice, and it has to be at least a mid size.
How much is "won't break the bank"? We all have different ideas for that and it would be most efficient if you give us a solid budget.
Just a question... whats the difference between a case,.. and a gaming case? i mean... i gave a generic case,.. does that mean my pc isnt a 'real' gaming pc? :P
No, but most ppl think that blue LED and a more stylish and eye-catching case is a gaming rig. IT depends on what ppl think I guess :P
well... i cutted in a quite big hole myself.. and putted a stainless steel roster into it.. also, i have red and blue lights in my pc... wich i can disable through switches i build in in the fron.. :P yes... its a $20 case.. and even better... i got it for free, since it was a leftover from the shop where i bought my grafic's cards :)
