i can't see the resolution more than 640x.......... in the game and has to with that resolution.Don't this game has more than that resolution?If yes how can i set to higher resolution?
Yes it does have higher resolutions settings. The settings are in the menus somewhere. I cannot tell you where exactly as I've not played it in a long while. If you cannot change it any higher then try installing the latest Graphics drivers for your video card.
Not helpful, The game is pretty good actually, Your opinion would mean more if you shared it in a more constructive, mature manner. Meanwhile your opinion was not asked, so if you cannot lend a hand to the problem it's prob. best that you don't post. Lets put this post back on topic!
