PLEASE PLEASE PLEASE Help!
TRD_Celica
Latley my computer has been VERY slow and almost every program this message pops up
causeing the program to shut down when clicking close :mad:
please help! this is my only computer.
Specs:
Virus
Specs:
It sounds like you have a virus. Run a virus check from your computer or the web. Also get an anti spyware program. There are many free ones. Try these sites:
Windows Defender:
http://www.microsoft.com/athome/security/spyware/software/default.mspx
Virus Scan from the Web:
http://housecall.trendmicro.com/
Hope that helps!! :)
yup ditto that. viruses and spyware can be a pain in the but if you dont keep up on it. get something like that and run them like once a week depending on how much you use your comp and such. Also make sure to keep them updated or it wont do you ne good
Get rid of FlashPeak totally and then try a fresh install of it. This is more of a software problem then anything else. Have you made any recent changes as far installation or removal of programs?
There's no faq section except for a forum when going to the main site. How long have you been using this browser? 3rd party browsers can be a nuisance at times to debug when program errors are seen. Often those automatically become the default browser. You could select the "error messages" link seen at http://support.megagate.com/downloads/ if you were on a dialup network.
Housecall from TrendMicro
This free system checking program just does not work on my system using Win.XP. It just runs and runs and gets nowhere.:( I think it's just a scam of TrendMicro to get you th buy the full program.:rolleyes:
That's what sharewares are all about! :P "you have this and that and need to buy.. buy... buy now or..... else! :eek:!!!" is the reaction they want you to see when some "imaginary" figure of 100 things need "their" software to fix. A shareware just tried here upon someone posting about it saw the trial period detect registared, valid hardware drivers being labeled as trojans! :confused: That was Prevx1 malware remover? It went after legitimate drivers instead. :mad:
