Ogg Vorbis + WMP11
Rambo
Anyone know how to add .ogg files to the library of WMP11? I have installed the codec, I'm able to play them with WMP11, but it won't add them...
Any ideas would be helpful, thanks :)
It may play it with a codec but I don't think it sees it as a supported sound format. .ogg is not very.....popular, which would explain why you had to install a new codec just to be able to play it. Why are you using .ogg anyways?
