Jet
Yeah i know. Ive had trouble with them in the past (thats why i switched from the stock intel hs) . Im telling you. This case has some really good airflow and the after market cooler dosent blow the air out into the case. It goes straight out the back. Check it out on newegg. I said the type of cooler earlier in this thread. The hs and fan are right next to the exaust fans in the back and then the hs fan blows the air through the hs and right out the exaust. But i really dont care if u all believe me. Im not looking for friends on this forum. I use it for ideas and advice.
I didn't find the model. Basically, the coolest single core AMDs run at 3-5C higher than Ambient, and no P4 can beat that, or come close, without undervolting and underclocking it.
My processor, even though it does the same thing that yours does (it blows directly out a 72cfm 120mm fan) it still runs 50C idle on a good day. Besides you running your AC at 60C, still your processor at should be running at least around 30C idle. I want to stop arguing now, but I would like a screenshot of whatever program you use.
