Out back, out top side, and out the top.
In front, and in on lower side, or right above the CPU.
Best to have negative pressure, then hot spots are removed.
If you only have one side hole, then it should be an intake.Out back, out top side, and out the top.
No, positive pressure is better. Then it forces the hot air out.Best to have negative pressure, then hot spots are removed.
Your power supply blows air out the back. If you were to change your other fans, you'd neutralize the fan on the PSU and possibly cause it to overheat...
if you have fans pushing air outside the case air still finds it way inside the case, if you install fans that push air inside the case air fill still find its way out.Yeah when it pushes air out all the USB ports and connectors act like air filters and become full of dust, can I reverse it and push cold air inside instead ?
