PSU in mind
I don't think it'll be enough. Only 350W and between the 12V rails only 34A. Whilest 34A is decent, for a system like yours, I'd go for 38A, and at least 500W. If you really want to cheap out on the PSU, go for this one: http://www.newegg.com/Product/Product.asp?Item=N82E16817174023. I personally have this PSU, and I love it, it's stable on the voltages, and is a great value.
Well for cheap it could be worse, but 350W i dunno what your running but be carful.
I plan on running the system in my sig.
__________________
My Fiance (Future PC)
AMD Athlon 64 X2 3800
Centon 1GB DDR400 PC3200 RAM
Radeon 9600XT 256MB Video Card
Sabrent 7.1 3D Sound Card
Maxtor 160GB SATA Hard Drive
NEC DVD+/-RW Drive
34A is the recommendation for SLI'd 7900GTXs. I can assure you, that with the system in question he won't need anywhere near that.
It's certainly a good unit for the price. Keep in mind that despite the two +12V rails @ 20A each, the total +12V output is only 29A. The Sparkle would also suffice for your system, but won't leave you too much leeway for upgrades. If another $15 won't break the bank, the XClio 450BL is a superb unit. Take a look at PSU101 for some more recommendations.
