E6400 Non-BIOS overclocking?
Rambo, you mean I don't have to go and disable all that stuff? Is there anything I need to disable?
Well, you will find that in the guide, it also mentions to disable those BIOS options, optional as it may be. This is because you want as low a strain on the chipset as possible, and disabling those features means it can "concentrate" easier on the overclocking, rather than running those options + overclocking at the same time.
It is just to reduce the workload of the chipset, in order for a cooler chipset, thus - a more stable overclock.
I don't know why you're having so much trouble finding these things anyway. It can't be that hard, surely...
