Bf2
pokemon87654
Yes I know BF2142 is coming out, but I hear it's pretty demading, and I don't think I can run it... :( But I had BF2 Installed a while back before reformating, and now when I install it, it will get to the third disk, then say fatal error, I retry it and it does the same thing as the same spot, what should I do, I tried my other disk, my brothers copy and it still doesn't work. For the primary IDE should I set it to PIO mode, becuase i think thats what it may have been at last time, even though im not sure what that does, it did it last time, but I thought that i would ask first, Thanks
For the definition of PIO go here http://www.google.ca/search?hl=en&lr=&defl=en&q=define:PIO+Mode&sa=X&oi=glossary_definition&ct=title and some more good reading here http://en.wikipedia.org/wiki/PIO_Mode
Have you changed any hardware since the last time you had the game installed? tried cleaning the optical drive?
As for Battlefield 2142, it's not much more demanding on your system then Battlefield 2 is. If your not certain how it will run on your system then you can download the demo and give it a whirl.
so looking at my computer, in my signiture do you think i can run it okay? I did system lab test, it said i would, but my video card was the weakest link..
