sammytheman
Hi fellas I was shopping for a new AMD CPU. I currently have 64 3500 which is like 2 years old. I see there is the opteron, X2, and FX. I am lost. Which one should I get for the best, long lasting bang for the buck?
			an X2 would be i think. the FX's are the best (fx-60 is the best s939 CPU,. but its bloody expensive, ditto for the FX-62,.. but that one's Socket A2M)
I think a 4400+ X2 would be the best bang for the buck atm
Unless youre a die hard AMD fan, get Core 2 Duo (conroe)... Nothing beats the E6600!
the 4200+'s and up are dual cores, 4000+ and belox are single. fx-57's and below are single cores, fx-60's and above are dual. the only difference between the regular athlon 64 line and the fx line, is the fx series have unlocked multipliers. other than that, they are identical. if you're not going to overclock, there's no reason to buy an fx processor.
What the hell is CONROE? 1st time I heard that. Anyways fellas I just want to add that I have 939 socket and my MAIN priority is GAMING.
Hey, PC eye, there's a difference between overclocking and unlocking multipliers... but please don't respond to this with one of your off topic stanzas, please don't reply at all.
Though there is a 4000+ x2.
 http://www.newegg.com/Product/Product.asp?Item=N82E16819103562R
  http://www.newegg.com/Product/Product.asp?Item=N82E16819103562RHi fellas I was shopping for a new AMD CPU. I currently have 64 3500 which is like 2 years old. I see there is the opteron, X2, and FX. I am lost. Which one should I get for the best, long lasting bang for the buck?
