SubDude199
Im new to your forum.. Im here for some help.. im not a newb when it comes to computers but this one has me stumped.. maybe someone else has had the same problem and knows the answer so im here for help.. thanks in advance
This is the second X1300 I had, Though the first one was defective because of what it was doing but this one is doing the same thing. So I am almost posative its not the card, its somehting else. Before installing the card I looked for a way to disable the OB video with no luck.. Nothing in bios - no jumpers, so i assume its auto. I also uninstalled the Nvidia Display drivers (still needed the Nvidia network card and other drivers for my mobo) Then installed the card and started up (could only get video out of the DVI port but im sure thats how all new cards are) once i pluged in my projector to the dvi port i seen the desktop.. this was good.. so i installed the drivers and restarted my computer like it said.. I surfed the web and watched a video for about an hour on the new card and it worked awsome, then when i went to test it out in a game and it looked awsome and worked awsome, I was gettin 98fps.. needless to say i was very impresed, I was only gettin 27-30 before the upgrade.. I went ahead playing the game but after 2 mins or so it froze and all i seen was a breen screen with lines on it.. I had no choice but to restart my computer. I tried it again with a diffrent game and the same thing happened.. I decided it might have been the DVI port or somehting so I tried it with S-Video and it also crashed. I check the biostar websight for BIOS updates to help this but there was none. To me this seems like the card is ok until u demand power out of it. maybe its starving for power. So i tried it on my other computer (biostar GeForce 6100 [NOT T-force] with AMD 3500+) and it did the same thing.. that computer has a 300 watt psu. Anyone know if an ATI card is compadable with this Nvidia based motherboard? I already lost a few bucks on shipping and the seller and I are not gettin allong so there is no way I can return the card so I need to see if I can get it to work. Any advise on what to try or what it can be.. Thanks for the help
(Update** Tried Drivers From The Cd and From ATI.Com With The Same Results)
