Ugh.. I hate how Newegg has things now... You can't search by processor speed! Any idea how fast that is?
DDR2 is actually faster due to the increased bandwidth. DDR2800 is obviously going to much faster then DDR400. One other difference is the 240 pin or contacts seen on DDR2 over the 184 pins seen on DDR. Both the bandwidth and the memory bus are faster. The slowest DDR2 is at 533mhz.
You'll probably find better value individually.And do those come with the processor? If not, then I need the cheaped one with a processor.
Noisnt DDR faster than DDR2? ........... the fastest ddr is faster than the fastest ddr2 correct?
DDR2 is generally superior, both in regard to frequency and performance, despite the latencies.by faster do you mean high frequency? ddr2-800 has horrible latenceys as far as ive seen
1. DDR2-400 is availableThe slowest DDR2 is at 533mhz.
If you're just looking for the cheapest possible solution, consider ebay as well.Whats the cheapest one you can find?
