check before you shut down the p.c. when the window pops up sometimes in past when you do restart the p.c. the settings stay the same and you forget to change it back.![]()
that wouldnt be the case in XP with the normal XP theme though as there is no drop down box, its a selection of buttons instead.
you can put up the pull down menu on that screen in XP tough![]()
