Which one of this is the best video card specs wise?
DSM1999
This one
Price 259$
eVGA-Geforce 7900GTO (650MHz clock)
512MB 256-bit GDDR3 (660MHz clock - 1320MHz effective)
PCI-Express X16
42.24GB memory bandwidth
OR
Price 269$
eVGA GeForce 7900GT KO (500MHz clock)
256MB 256-bit GDDR3 (750MHz clock - 1500MHz effective)
PCI-Express X16
48GB memory bandwidth
the GT KO is an overclocked GT as far as i know,.. the GTO is a underclocked GTX (or at least comparable with)
so,.. i'd go for the GTO too tbh
hey do you know if i can run it with a Dell XPS 375watts stock powersupply?
since the GTO minimum requirement power supply is 450watts?
two things:
1: maybe, just dont overclock it...
2: you dont have a socket 939 mobo... you have a 775 and its a Core 2 Duo
they are better than the s939 pc's Ku-sama wanted to say :P
As for the power supply... im not sure if its strong enough.. you could give it a try.. worst case scenario, you would have to spend 50-60 dollar on a stronger PSU to run it.. ( so please keep that in mind if you decide to but such a card)
