What laptop should I buy...
dannim12345
I'm planning on buying a laptop, I don't really want to spend more then £550.
I just want it for music, to do some work in word etc, a cd rewriter, not too big or heavy, wireless and good enough to play the odd game of the sims.
Can you recommend any laptops? Or if not can you recommend good any brands, or brands to stay clear of.
thanks :D
£550 is $1,030.92
I've found a sony which looks preety good it's £499 ($935.29).
This is the sec :
Operating system Microsoft® Windows® XP Professional
Microprocessor Intel® Pentium® M Processor 740 1.73 GHz
Microprocessor speed 1.73 GHz
Language version English
Main usage Business
Standard memory (MB) 512
Memory specifications DDR2-533 SDRAM (1 x 512 MB / max. 2 GB with 2 x 1 GB)
Cache memory (L2 - KB) 2048
Hard disk drive capacity (GB) 100 GB
Floppy disc drive Not Supplied
Interfaces on docking station Kensington Lock hole;Printer port;Monitor (VGA) port;DVI-D port;DC In port;4 Hi-Speed USB (USB 2.0) ports (high/full/low speed);Network (Ethernet) port (1000BASE-T / 100BASE-TX / 10BASE-T);Multi-Function Bay
Display size 14.1" (35.8 cm)
Laptop Screen Resolution TFT 1024 x 768 XGA X-black LCD
Graphics chipset INTEL® GRAPHICS
Graphics memory MAX 128MB SHARED WITH MAIN MEM
Multimedia Intel® High Definition Audio compatible;Windows® Sound System Compatible and 3D Surround;Built-in Stereo Speakers
Interfaces Headphone Jack;VGA connector for monitor;3 x USB 2.0 (High/Full/Low-speed);DC-In;Memory Stick(TM) Slot (MS Pro and Duo compatible);Multi function bay docking station connector;Microphone Jack;SD card slot;4 pin i.LINK(TM) (IEEE1394), 400 Mbps;RJ45 Direct port Ethernet 1000 BASE-TX/100 BASE-TX/10 BASE-T;RJ-11 direct port
Modem Built-in modem V.90/V.92, K56 flex, Fax/Modem
PC card slots 1 x PC Card type I or II and Card Bus support
Lithium-ion battery VGP-BPS4
Battery life up to 2.5 Hours
Dimensions (W x H x D mm) 335.9 X 33.4 - 36.3 X 283.3 MM
Approx. Weight (g) 2,500
Pre-installed software (Imaging) Adobe® PhotoShop® Elements (Image editing software)
Pre-installed software (Movie & Video) WinDVD(TM) for VAIO
Pre-installed software (CD(DVD) Burning) Roxio Digital Media SE
Pre-installed software (Utilities) VAIO Recovery Utility - HDD Recover;WebEx;Google software package
Pre-installed software (Others) Norton Internet Security (AntiSpyware edition);Microsoft® Works;Adobe® Reader;Adobe® Acrobat® Elements;Microsoft® Office 2003 SBE (trial version)
Supplied accessories Power Cord;Lithium-ion battery;AC adaptor
Bluetooth(TM) Supplied
Wireless LAN Wireless LAN IEEE 802.11b/g
Integrated CCD Camera Motion Eye Yes
Try this http://www.cyberpowerpc.com/r05/ri05.asp
also dell and toshiba make notebooks with better specs for the same price..
£550 is $1,030.92
This is the sec :
Main usage Business
£550 is $1,030.92
This is the sec :
Main usage Business
I would shoot for a Intel Core Duo and 1GB RAM. Dell has some good prices.
ThinkPad
I've found that the Toshiba Satellite series is very reliable
HAHAHAHHAAHAHA
yeah right..
well actually, I've had 2 Toshiba's. The first one was great and lasted me a long time. Then I got another Toshiba in 2004, it was the worst laptop i have ever owned. Not even after two months after buying it, I started having problems with it. The AC adapter completely shit the brick, Toshiba wouldn't send me another one unless I sent them the whole damn laptop. I send it to them, It took FedEx 1 week to get it to them, took Toshiba 2 weeks to look at it, then they said it was the AC adapter (i was like "no shit"), then it took them a week before they actually sent it back to me, and of course it took FedEx a week to get it back to me. Then less 2 months later, the connector for the AC adapter went (inside the laptop) so rather than mailing it in I brought it to one of their subcontractors that was 50 miles away. I bring it to them, I told them exactly what the problem was and asked them if they would fix it under warranty, they said yes. So I left it there on a Friday, I drive back home, theres a message on my answering machine (jerk should have called my cell phone to save me another 50 mile drive) and he says "thats physical damage and it's not covered under warranty, it's gonna cost you $90.00 USD". I said "WHOAAA SCREW THAT!!!" I picked up on the Monday cause they were closed on the weekend, I open the thing up, and the solder job they did on that thing was the worst solder job I've ever seen. It amazed me that it lasted as long as it did w/o breaking. there was like, a ball of solder on the lead of the connector, but no good contact w/ the PCB. So I soldered it, put it back together. and it worked for a while. but then I started having weird problems where if I disconnected from the AC adapter and went to battery, the sound wouldn't work, or the computer would completely hang. and then I started having problems w/ the keyboard where keys just started popping off the keyboard as I would type. (I do a lot of typing, so it just can't handle it I guess) and of course Toshiba covered none of this under warranty. So the thing was getting on my nerves enough where I went out and bought an ThinkPad. I absolutely love my ThinkPad T60, I've had it for a few months now. The thing is the best and can take a beating. I know someone who dropped their ThinkPad down a flight of stairs and had not a scratch. It's very light, and I can easily get 5 hours of battery life of constant use. If I try hard enough I can usually get up to 8 hours (or more). (I have the 9 cell battery instead of the 6 cell, and I do NOT have the extra UltraBay Slim Battery) The only complaint I have w/ the T60 is that the 14.1" screen has very poor viewing angle and contrast, and certain odd 3 button key combinations cause keyboard errors (like Space + Up + Left bugs me if I'm playing a driving game). A Thinkpad cost a little more than a Dell or other mainstream computer would cost but I think it's worth the extra cost.
New ThinkPads
Refurbished Thinkpads
but, I learned my lesson trying to save money and buying a Toshiba, you're better off in the long run to spend a little more money and buying the laptop you want then buying a laptop, hating and and having problems with it and then buying another one a year later.
BTW ThinkPads used to be made by IBM, now they are made by a company Called Lenovo, which has always been involved in the manufacturing of ThinkPads, but now they own the whole IBM PC division, but the quality of the product has not gone down, and the computers are still IBM branded.
Seems like I hear people say that their Toshibas were junk. My mother is a writer, and writes all day long 6 days a week, so it gets more use I would think then normal. She has had it 2 months without a hiccup. Hopefully it will stay that way. Time will tell……
