Intel intergrated extreme graphics 2?
ausieborn
Can someone tell me what size of memory the card might have:confused:
the computer i ordered has it and apparently its better then a geoforce 6700e
Is it considered a video card? Can it run games smoothly? If so what other cards could you compare to it?
It can't be better then the 6700, since the Intel Extreme Graphics 2 is an integrated GPU, which uses shared memory. Basically, it's crap for 3D applications. You may be able to run CS 1.6, depending ont he CPU, but dont plan on playing any newer games.
Depending on the specific type, it may be 64MB, 128MB, or 256MB.
geforce 7600 is good, im not sure of the price tho...
^^^i have that :D
EDIT: nvmd, its $255 lol
nvidia:
6200
7300
ati:
x1300
9550
*PNY cards are in the cheaper price range
nah its a pretty bad card for gaming that is so if you plan to game go for the x850pro its a good agp card if thats what slot you have
