Official Screenshot Thread
If someone could fic this for me and get rid of the rest of the crosshair, that would be great... it was hard to get a good one like this tho.
I'd wish I had taken a screen shot of this but in Oblivion, I came across two Legion sholdiers shooting at each other for no reason..... It was hilarious because they were yelling the same things at each other..... Eventually one killed the other and ran off...... What else could I do but loot his corpse for some freebies......
do you know this one?
I can only afree with Ku-sama. ( altough,.. at first glance a F-117... blasphemer! :P )
how did you manage to get it into that position tough, (dive and then pull up? ) the B-2 engines arnt strong enough to do that without diving firt, or you'll stall =)
yea, a sudden drop then straight up.. it actually continued going up without stalling for few thousand feet. lol
Filip,
What graphics card u got yourself there?
Looks great.
Ya thx, they look ok.
Those screenshots were taken ~3 months ago and back then I was using a X800GTO2 (flashed into X850XT), now I have a 7900GS, and there is no eye candy at all, I'm running it @800x600, and with a lot of stuff disabled throught the console commands.
Why do you have the settings that low on a higher end card?
Probably due to the older ATI model card being better suited for the system used there. Once you get a system fine tuned just right "do not touch" should be posted on it. :P
