New build
Hawk16
okay, so i guess my dream comp aint coming for a while so i guess ill make a budget one.
i have a budget of around $1000 give or take an extra $300 for monitor, mouse and keyboards and other stuff like that.
it is in canadian currency as well
so i guess i wanted to start of with
AMD Althlon 64 3200+
Good cheap mobo
250 gb hd
cheap good PSU
DVD burner
1 gig of ram
and a good cheap case
for a graphics card im not sure but i want it to play mid intensity games like CS:S and WoW
maybe bf2 later on
~HaWk16
Hey man, really you don't wanna be spending a grand on the really, since your in canada, pick up a prebuilt if you need a comp just for now, or do what i did, go to ebay and by the parts there from a store with a good rating, you'll save alot, if you can build up the 1000.00 and then build your baby
I disagree very firmly with damientbayless, it will be MUCH cheaper if you build yourself, rather then buying a pre-built computer.
Also, if I were you, I would get an Intel Core 2 Duo...they currently beat the A64. But if you're future-proofing, and want to make sure you can upgrade to the latest and greatest (i.e. quad-core), I would prob get an AM2 board...
well the thing is i dont need a computer which can last for a long time
just maybe around 4 years till i get a laptop for university and stuff
and it doesnt have to be made for hardcore gaming cause i dont do any
i just need a budget compy to replace the sh*tty one i have
You say your budgets $1000, you can get a really decent rig for that if you shop right.
Conroe E6400 - $220
1 GB Corsair PC 6400 Ram - $155
7950 GT 512 MB $300
GIGABYTE GA-965P-DS3 Motherboard - $140
320GB 7200RPM Hard Drive - $100
Good Powersupply - $75
Case - $40
CD/DVD Drive - $30
Total - $1060
But if your not an avid gamer, you could downgrade alot of that stuff. Esp, the video card.
Well, if you're looking to just buy a cheap computer, AMD is currently the cheapest. If you're looking for good performance (multi-tasking, etc) at a decent price, get a Core 2 Duo.
Nothing will last for 4 years, especially a budget PC.
heh, u sure about that?
this computer has been running for about 4 years now
and it can still play some of the not so new games but little older ones
and it still runs fine i just wanted some more power to play just a few of the newer ones and run programs a bit faster
(this comp is the sh*tty one in my sig)
