[-0MEGA-];473424 said:The 108Mbps routers use the G standard, however each company has their own way of achieving the 108Mbps rated speed. So yes, you can use any other G device and it will run at 54Mbps, but most likely you would need to purchase identical client cards from the same manufacturer to achieve the rated 108Mbps.
Also, though I am not sure if this is true for all brands, you can only get the 108Mbps if all wireless devices on the network are capable of doing so. Should a device that only does 54Mbps come onto the network, then all the other devices would downgrade their speed too. I believe this is what happens with dlink products but not sure about others.
108 Mbps is a feature of wireless adapters and routers based on the Atheros chipset. As long as all the harware uses the Atheros chipset, it should connect at 108 Mbps, though real-world rate will be less than that.
Which was precisely why I used the term "should."[-0MEGA-];475328 said:Some manufacturers may be compatible, but most likely they won't be.
very very true, and very worth noting, most cards cant reach the 54Mbps let alone 108. we'll need to wait for 802.11n for better universal bandwidth.though real-world rate will be less than that.
the word "should" implies that the balance of probability is in favour of the event. In this case that is unlikely and a better word would be "may". Omega was just clearing up a little ambiguity in the statementWhich was precisely why I used the term "should."
