Its a CAS Latency, its a timing on the RAM module, lower timings means it takes less time to do stuff..... thats about as simple as anyone can make itwhats CL1?
1-1-1-2? that not a step up from 2.5-4-4-8?
Timing 2.5-4-4-8 Voltage 2.7-2.9V
thats at DDR600...
it is, at DDR400 which has it underclocked by 200MHz and overvolted to 3V it had the RAM running at 1-1-1-2, but it wasnt stabe enough for benching, but it did show up in everest as 1-1-1-2
If running at DDR400 is underclocked by 200MHz, then it was originally DDR800. Please make sure you stay accurate, it was underclocked 100MHz.it is, at DDR400 which has it underclocked by 200MHz
