When I turn on the PSU switch, cpu and case fans start spinning.
There is no video or POST, unless I press the mobo power switch.
I have seen others have this problem thinking the mobo (and everything else)
is dead, when they only need two power switch presses.
I don't have to do this with other Asus mobos, so why here?
Mobo: Asus P5LD2 with latest BIOS
PSU: Antec Smart Power 2.0 450 W
Since most P5LD2 owners don't seem to have this problem,
I'm starting to think Antec's PSU is somehow incompatible or damaged.
The same Antec PSU does work as expected with a different Asus mobo.
I thought I should share this, since the workaround is very simple.
Strange that two power switches are need to start the boot.
It is almost like only one PSU rail turns on and then the other rail,
completing the power requirement.
