monsteromen
can any1 tell me something bout this card because i'm planning to buy it? is it good?
ATI updates no longer run on that or the 9550SE 256mb model. You can look over the details on that one at http://www.gecube.com/products-detail.php?prod_cat=34&prod_id=21234
The following links are a little closer to home for ordering a replacement or newer make and model.
http://www.hmrphil.com/classification.asp?er=1&pg=1&class=COMPART
http://trade.indiamart.com/offer/computer-hardware/computer-hardware/buy.html
http://www.hardwarezone.com.ph/priceguide/priceguide.php?id=234&Submit=Go
The Catalyst won't run well after the 6.1 update on the 95xx series cards if you plan on gaming it all. The drivers only option will continue upto the latest. It won't take long before the entire 9xxx line is no longer supported. This is why moving upto an X1600 model card will keep you going longer before moving into PCI-E. You want to go forward not backward when choosing.
[-0MEGA-];477761 said:ATI states that any video card which is at or below the 9250 doesn't support the new drivers, and you must use Catalyst 6.5 or lower. It doesn't say anything about the 9550.
I ran the 9550SE on the last build. That was the 256mb model and went through the newer Cat.s to find out which ones would or wouldn't work. I went back after the 5.11 Control Panel after running the Cat 6.5. The 9550s have the 9600 model chip in them. At this point you would want to go with the AGP version of the Radeon X1300 and X1600 Pro or newer for gaming. The X850 was a great one for gaming.
Gibberish-it still supports the 9550
You run in circles around and around a misstatement![]()
