Recovery
Liverpool
Suggest me any good software(Full Version)for recovering my Data(.Jpg) which I accidentally deleted from my HardDisk .
Besides the free to try Data Recovery software seen at http://www.data-recovery-tools.com/2006/07/site-map-data-recovery-softwares-and.html there are several freeware utilities for retrieving lost data and files that have been deleted by accident. You can the few links here a try.
snapfiles.com and download.com alike often have some great freewares available for download. Here's a link for those found at snapfiles.com http://www.snapfiles.com/Freeware/system/fwdatarecovery.html
You can even search several data recovery sites at http://www.data-recovery-tools.com/free-data-recovery-softwares/
Undelete is a popular shareware found at http://www.download5000.com/page9543.aspx
Download has several others seen at http://www.download.com/3120-2001_4...link=&gfiletype=&os=128&li=49&dlsize=&ca=2018
Thanks .I'll try everyone of this.
Actually I used Boottable cd to format my C: drive for installing WindowsVista.
I forgot to back up.
So can I still use those software which u mention above?
As i know, to recover data by using these software, you must install them before deleting any data.So you can't recover anything now
No.
I can recover some files by using PC Inspector File Recovery . But I can't still see my data(.jpg). Meaning it recoverd the files as .jpg but if i showed it in the (windows pictured and fax viewer) ,i couldn't see.
Oh really? :rolleyes: How do you think data recovery services operate? They don't install anything on your drive before they retrieve data and files. It depends mainly on the amount of magnetic residue remaining that determines how much and in what condition files are able to be recovered.
What you see is what you get unfortunately. This is why frequent "backups" seems to be the one thing that eludes people. You can try other recovery programs but it will depend on how much of the file is left intact. The actual percentage of the file recovered will probably vary between softwares. There was a program called "Undelete" available at one time. But if the file was corrupted during the deletion process you will get what's left of it only.
Hi,
Thanks for the information. I'll try the program which u gave me for finally .
To:pc eye
The software which u told me(undelete) doesn't scan my C: drive. Why is that so? But It scans other drives.
With some of these recovery programs you may have to create a recovery floppy or bootable cd first in order to run them. You first have to go over the specific "readme" file that either comes along with the download or refer to the online ttutorial. Emergency Undelete is one of the utilities that does. The professional version includes that tool. The online manuals for Undelete are available in PDF file format at http://support.undelete.com/support/manuals.aspx?Page=5&Subpage=4&cust=1&RId=1&CId=1&SId=2
