Will FSXwork on my pc?
Shane
Super Moderator
Hey people,
Do you think Flight Simulater X will work on my pc?
Maybe wih the graphics set to low or even possible Medium settings?:confused: :D
Just thought i should ask before i download the demo because im downloading other stuff atm so i wont download it till tommorow anyway so should i bother downloading or can i expect bad results?
Thnks;)
* Windows XP SP2 / Windows Vista
* Processor: 1.0 Ghz
* RAM: Windows XP SP2 - 256MB, Windows Vista – 512MB
* Hard Drive: 14GB
* Video Card: 32MB DirectX 9 compatible
* Other: DX9 hardware compatibility and audio board with speakers and/or headphones
* Online/Multiplayer Requirements: 56.6 kbps or better for online play
I'd say your computer is well within those requirements
Alright thanks...Are those Minimum requirements then because they seem a litle low:confused:
I cant see a 32MB DirectX 9 compatible card cutting it:cool: Jeez i cant see my card cutting this game the graphics look great.
yea minimum id assume
btw my computer played it fine on low and medium settings so yours will probably do pretty well with the game
And with Microsoft, that means minimum without having your computer melt from overstretching the resources, like with XP... :) Anyway, yeah, that's probably with everything turned all the way down/or off. On yours, should run on medium like Redbull said...
Downloaded it today and it ran fine on Medium settings which i didnt think it would.
