Riboflavin
Wrong again, if you have really looked at a power connector the top edges are cut at a angle the bottom is square, you cant plug it in wrong and a missing pin will not stop you from plugging something in, if you had a pin where there is no hole that would stop you but that is not the case here!! Its a extra ground that some power supplys have and some dont!
So either way it isn't the problem?
