JEDEC standard ram & non-ECC ram
b3atofang3l
Hey, i am wanting to buy a Mushkin EM2-5300 2x1GB JEDEC standard ram, however, i can also buy the Mushkin HP2-5300 (eXtreme performance type) that are not JEDEC and can be overclocked...
are there difference between JEDEC and non-ECC ram??
Thanks
JEDEC doesn't mean it's ECC. There is no reason to buy ECC RAM for a desktop PC, and most motherboard won't accept it as far as I know.
JEDEC is a standard, and most if not all 965 motherboards require it, because non-JEDEC compliant memory may run over 1.8v, and therefor may not work in most 965 motherboards.
......? You still h avent answered my question, i am trying to ask if non-ECC can be consider JEDEC?
b) is JEDEC slower than other memory?
You don't understand, JEDEC is a standard, not a type of RAM.
JEDEC is mainly non-ECC< but there may be some JEDEC ECC as well.
JEDEC compliant RAM simply means that the memory has to meet a certain criteria, such as it can't go over 1.8v. So some motherboards (mainly the 965 series), can't support RAM over 1.8v, so in other words, it has to be JEDEC compliant.
So no, JEDEC RAM doesn't necessarily mean its slower.
