W workwithcomputer New Member Nov 10, 2006 #1 how to make windows messenger do not run automatically when computer start ? who can help me ? thanks!
b3atofang3l New Member Nov 10, 2006 #2 ...u click tools on the top, then go to options. there is a selection in there..
W workwithcomputer New Member Nov 10, 2006 #3 thanks a lot . but i yet have not understand what you said . could you specify what you said just now ? thanks!
pdc76 New Member Nov 10, 2006 #5 chrisalviola said: you can use msconfig and uncheck yahoomsg Click to expand... he's talking about windows messenger, not yahoo messenger.
W workwithcomputer New Member Nov 10, 2006 #6 thanks a lot! windows messenger runs when pc starts. how to make it doe not work together with pc starts. i simply want to make it run whenever i want. who can help me ? thanks!
pdc76 New Member Nov 10, 2006 #7 first you need to "make it run", lol. look in the settings, there should be an option to start when wndows starts. you do not want that option enabled.
J jiSh New Member Nov 10, 2006 #8 In Preferences inside Windows Messenger there is an option to start with Windows. Simply untick that. Avoid msconfig as anything other than a reference tool.
W workwithcomputer New Member Nov 10, 2006 #9 thanks a lot! i test what you said . when i have questions about it. i will ask you later.
b3atofang3l New Member Nov 10, 2006 #10 run Windows Messenger, Click Tools on the top bar, then click options on the bar that comes down. in opitions, go to general, then untip "automatically run when windows stars"
