he wants to do it during certain times of day and have it run on a schedule, not when a program hangs. unless you've found a way to predict the future so you know exactly when a program is gonna hang.
Those were the freewares found. A more intense search would probably turn up a few with a builtin scheduler like DShutdown 1.65. http://www.download5000.com/page21976.aspx or how about ???
There's Kill-Win: http://www.bk-soft.com/killwin.htm
You do have to start it manually unless you put a shortcut in the Startup folder. Works for me.
Tom
There are quite a few if you run an extended search or two. There's also some for remote shutdown of systems or auto shutdown if the user is away from the system for any period of time. One was for network use there.
Glad to see it worked out. Remember to save the link there. You have to run a search to locate it since that site is packed with other freewares and sharewares.
