I just ordered this Is it good stuff? I usally use corsair but I thought I would try this.
I am upgrading from old 1gb pc2100 ram, will i see a big improvement?
Thanks,
Well I put the new ram in yesterday and went into the bios and its on auto detect for the timmings, its saying CAS 3??? Also there is a list of timmings that I dont even want to touch cause I have no clue what they mean.
Any suggestions? Should I just leave it on auto? I dont want to make it unstable.
Thats what the tech guy said at kingston lol.
I just want the ram to run at full potential. I bought it thinking it was CL2 and fast timmings for gaming and it was a little disappointing thats all.
well.. 8% is still quite a lot imo.. anyhow,.. is that the only RAM in your pc? or do you have some other sticks in it? ( if those others have CL3,.. i dont know if you can put it to CL2,.. but if not,.. just put it on CL2, and you'll be fine )
Those are the only 2 sticks I have in there, I have a asus A8N-SLI prem. mobo and it has a bunch of timming settings? Should I just change the CAS# to 2 then and leave the rest?
well... set it to the timings of the kingston RAM, and try to boot... if it doesnt work, you know the timings were too tight ( it will reset the bios then)
Total kit capacity is 2GB (2048MB). Each module pair has been
tested to run at low latency timing of 2-3-2-6 at 2.65V. The SPD is programmed to JEDEC standard
latency timing of 3-3-3-8 at 2.6V. Each 184-pin DIMM uses gold contact fingers and requires +2.6V.
The electrical and mechanical specifications are as follows:
