kof2000 New Member Nov 12, 2006 #1 anybody does this too? think there will be error on them sooner than using page files along with them.
palmmann banned Nov 12, 2006 #3 jp198780 said: you can do that? didnt know that lol.. Click to expand... if he means the pci cards that take like 8 gb sticks of ram and make it seem like an ultra fast sata hard drive, then yes.
Shane Super Moderator Staff member Nov 12, 2006 #4 Are you talking about using Page file here? If so ive set it to no paging file on my comp.
Saurian Member Nov 12, 2006 #5 If you have enough ram, you can flip off the page file, or else turn it down. Those DDR drives are pretty cool too, except for the need to maintain constant power to it.
Shane Super Moderator Staff member Nov 12, 2006 #6 kof2000, If your talking about the computer in your siggy then turning of Paging file with 2Gb of memory will be fine. I have it turned off on mine and its realy fast.
