pdc76
i have an fx-60 and a zalman cnps5000 cooler. i put artic silver on when installed it, let it run for a few hours, and shut my system down overnight. i haven't overclocked for about 2 weeks so it could cure.
so i'm reading a post and decided it was time. i raised the multiplier to 13.5 and got the stock 2.6ghz up to 2.97ghz. i thought it was running a little on the warm side at stock settings: 48c idle. since the oc, it's idling at 58c. is that too hot? i'm afraid to put a load on it.
i used a proper amount of as5, properly seated the hsf, and i even got the fan cranked up all the way (2550rpm). is this a normal temp, or should i back off alittle? you'd think the cooler would do a better job even at stock speeds.
ps: the side is off my case and my mobo temp is 29c.
