my computer- tool- file option
and choose "use classic windows style folders"
I don't know what exactly the word is,becouse my system language is not English.
it may help
i would have to say that is very unlikelyIt's definitely a piece of Windows Explorer that wasn't completely installed.
i said it was unlikely to be the solution, i should have made it clearer so i'll say it this way... it is so unlikely that i would bet my user status ...what say youBefore saying anything maybe we have to wait to see if he used the sfc /scannow
no the suggestion to change the view setting will solve the problem forever, hence it is the solution... in fact it is the only solution.The suggestion to change the view was to see if the problem persisted not as a solution.
errr.. was that a dealyou seemed so sure of your advice before, seems a fair bet to me.... shall i accept silence as a yes?
in the mean time ANNR maybe you could try one or 2 of the suggestions
Yes, and it bore no relevance on this caseDidn't you review the article on "missing tool bars"
The sfc will not solve this problem, it would be like recommending a disk refragment.... totally pointless in this caseIf ANNR used the system file checker already then you won't have anything to worry when the view settings are changed.
and?Upon completion of any Windows installation that's used before the list of programs are installed in case something didn't go on right like a bad install.
well you logged on now, and I still don't see an answerHow can you say "silence" when nobody could even logon?
