Okay, here it is
System Information
Time of this report: 11/17/2006, 21:49:40
Machine name: AREA51
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: ALIENWARE
System Model: m5500i-R3
BIOS: Ver 1.00PARTTBL
Processor: Intel(R) Core(TM)2 CPU T5600 @ 1.83GHz (2 CPUs)
Memory: 1022MB RAM
Page File: 412MB used, 2046MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Display Devices
Card name: NVIDIA GeForce Go 6600
Manufacturer: NVIDIA
Chip type: GeForce Go 6600
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0148&SUBSYS_22951584&REV_A2
Display Memory: 256.0 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.7810 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 9/28/2005 14:38:47, 3912192 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 9/28/2005 14:38:50, 3208800 bytes
Device Identifier: {D7B71E3E-4208-11CF-B668-9F0203C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0148
SubSys ID: 0x22951584
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_08800000&REV_1008
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5200 (English)
WHQL Logo'd: Yes
Date and Size: 6/2/2006 20:06:00, 4123136 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 31
