if i understand you right, yes you can.
you are talking about having 2HDD's in your computer and storing music on one and the OS and software on the other? right?
yes its very easy, if you have a second hard-drive, set it to slave (most hdds show how to do that on the hdd itself) then install it and it usually just kind of works.
How do you do this? thanks!![]()
[-0MEGA-];497610 said:You can manually move it, or change the "My Music" target to the other HD, so anything that goes into that folder automatically goes to a different HD.
