500gb
It's a little cheaper...I bought two WD 250gb drives and have them running in RAID 0...
Bigger drives are more prone to corruption and bad sectors, etc...also the reviews on the 500gb WD aren't great....
No, you probably will not have a problem. A lot of the reviews on newegg say the drive failed fairly fast or was DOA.
Personally I'd take the seagate, it's cheaper for a better drive.
I'd just order the seagate anyway if it will let you. If not the WD and a samsung drive are the only ones left in your price range.
