Do you know why I have this glich in cod2?
compfreak4334
During random times, some soldiers will just stop moving, and have there arms spread, and cant be killed. What could cause this glitch?
Is this online? Does Call of Duty 2 even have online play? Funny, I've played it and yet I do not know :). If you were online and experienced this, then It sounds like lag. Offline? then I don't know.
Patch the game and update drivers if needed.
Yes it does have online play, but I was not playing online. Its so scarey when they just out of no ware turn into a zombie.
so nobody knows?
Well.... If your still looking for advice, why not keep us updated? So did you patch the game? did you update your drivers? have you swept your PC for spyware and virus's? have you defraged and run routine maintenance?
I mentioned the patch and driver update but there was no response on that ;). I'll try and think of other ideas once you respond to already made suggestions.
Edit:
What are your system specs? Also, have you always had this issue? how do other games run?
Edit:
other games run fine, no viruses or spyware and I did patch the game.
Well that sounds like a very strange glitch. Perhaps you should remove the game and delete the directory's then re-install.
