External grahics card?
JamesBart
ive been searching and cant seem to find one. is it possible? the reason i ask is that i want to make as much of the inside of my computer external due to power and put a couple of HDD's in.
so if external graphics card that are also powered external exsit. could you please send links and information my way. thanks! :D
run a pair of 'em!
System Interface
# PCI Express® x16 slot (up to 2 NVIDIA Quadro Plex per SLI certified system)
yeah spend $100 on a new case and $150 for a good 550-700 watt PSU
if you want more room get a full tower case
could i do that wit my dell computer? i wouldnt know what case to buy and could i overkill me computer with so much power? could i fry my motherboard etc? its def a good idea.
also if i got a bigger psu and a bigger case could i have more internal hdd's? or does that depend on my motherboard? and could i overkill my cpu?
Thanks! :D
i think i may need another solution. i cant beleive how expensive they are! its complete madness. i was think maybes $2000 at most but not $20,000.
well i need to go and make some money if i want one of them. thats crazy! :P
If you were considering $2000 for a graphic card you could get a whole new computer. if you built your own and got a good mobo you could have plenty of hard drives. my mobo can support up to 4 i think or 6 sata cards. and you can get pci cards with sata ports.
