Another noob in need of help
ALI1
Everytime I Turn On My Computer, It Gives Me The "failure Boot Disk, Insert System Disk And Press Enter". In Order For Me To Fix This, I Just Go Into My Bios, Then Exit The Bios. And It Works Fine...... Why Does It Keep Doing That???
if i restart the computer, it will not give me the message. It only happens when i completely turn off the computer, then turn it back on......
if it was a failing battery, would it give me that message?
Yeah. If you shut the computer off and turn it back on, the battery should keep the settings. In your case it's not.
Check if you have a floppy or a CD in the computer. When you leave a floppy in there, and start a cold boot sequence, the BIOS thinks your trying to boot from the floppy. Remove it.
