Shane Super Moderator Staff member Dec 4, 2006 #1 Hi, Whats a good safe temp for a Motherboard to be at? Mine usualy stays around the 30-35c Mark is that ok? Thanks
Jet VIP Member Dec 4, 2006 #2 Nevakonaza said: Hi, Whats a good safe temp for a Motherboard to be at? Mine usualy stays around the 30-35c Mark is that ok? Thanks Click to expand... That's fine. Just so long as it doesn't go over 45C. (I have two sensors, one is at 32-38C, the other at 40-45C)
F flash527 New Member Dec 4, 2006 #3 You're at a safe temp, as long as you don't get up past 50 or 55C you'll be fine
N Niskyspy New Member Dec 8, 2006 #5 mine went to 65 once, cuz of the stupid IDE cables, so I switched to round once for CD-roms and got me two SATA Hd's with them lil cables. Now it running at 32 all the time
