hi all.....when i go and type in an address into the address bar at the bottom of my desktop i get this message......application not found,is there away i can fix this thxs
Can you take a screenshot of it? When I attempt it on mines, all I see is the word "Address" and no working input field or anything. If it's not that one, are you using a third party tool that you just installed?
there is an address bar in my task bar at the bottom of my screen...when i go and type an address like www.google.com then i press enter...and then i get this message saying application not found
Well, it seems like it's pointing to your browser, but isn't finding it. Do you have a default browser? IE, FF, or opera? If so, go into it's settings and check to see if it's set to detect as the default browser.
Other than that, you can check the properties of the taskbar. Click on "Start Menu" > Then click "Customize"
Near the bottom where it says "Internet," is there a browser selected?
