You should read a bit more carefully, especially, "...all or our motherboards support over volting cpu's". It doesn't make a bit of difference if the mobo cost a nickel or $500, if it doesn't do what they say it does. There are cheap mobos out there, but $94 aint cheap, especially when it doesn't perform as manufac. says it should. If you wouldn't complain to the vendor re. this sort of problem, then that is your choice, not mine.
In the last few days, I've spoken to tech support at DFI and Gigabyte qualifying a couple of mobos that have been recommended by the helpful fellows that have posted responses to my other posting on this forum, and both were busy, but were still very forthcoming and consumer friendly, and answered my questions. Their behavior, as was Newegg's, was markedly different from that of Asus. Clearly, I handled this differently than you would have, but I believe my efforts have been fruitful, and maybe helpful to others who might find themselves in a similar dilemna with an inadequate product from a manufacturer who is unhelpful.
