Adam135 New Member Nov 25, 2006 #21 http://www.newegg.com/Product/Product.asp?Item=N82E16815100126R Any good for you?
g4m3rof1337 Active Member Dec 7, 2006 #22 is that GUARANTEED to be a capture card and tv tuner card? anything bit cheaper?
Motoxrdude Active Member Dec 7, 2006 #23 I got a cheapo one from newegg ($30) and it works great! Too bad they don't carry it anymore. For under $100, i think this is your best option: http://www.newegg.com/Product/Product.asp?Item=N82E16815116625
g4m3rof1337 Active Member Dec 7, 2006 #24 http://www.newegg.com/Product/Product.asp?Item=N82E16815116626 what bout that? for both my uses
Motoxrdude Active Member Dec 7, 2006 #25 g4m3rof1337 said: http://www.newegg.com/Product/Product.asp?Item=N82E16815116626 what bout that? for both my uses Click to expand... Any tv tuner card can capture btw. That card is not good at all. Do not buy it. My cousin bought that card and it was complete garbage. It froze his computer every 30 minutes or so and the quality was horrible.
leSHok New Member Jan 25, 2007 #27 the one i linked you to earlier was external ADS tv tuner (on tigerdirect) idk if the rebate is still good but check it
