whats pagefile?
The famous copy and paste...:D
In storage, a pagefile is a reserved portion of a hard disk that is used as an extension of random access memory (RAM) for data in RAM that hasn't been used recently. A pagefile can be read from the hard disk as one contiguous chunk of data and thus faster than re-reading data from many different original locations. Windows NT administrators or users can reset the system-provided default size value of the pagefile to meet their particular needs.
I have mine disabled :)
Yes you only should disable it if you have 1gb of memory because if you have less it will slow down your system.
But i see you have 1Gb of ram in your Dell Dimension so i say go ahead and disable it.
Heres how to do it...
1. Start the Control Panel System applet (go to Start, Settings, Control Panel, and click System).
2. Select the Advanced tab.
3. Under the Performance section, click Settings.
4. Select the Advanced tab.
5. Under the Virtual Memory section, click Change.
6. Select No Paging File and click Set.
7. Click OK.
I don't recommend disabling it
It's useful for your computer
Well which one do you want to disable it on 6071842?
I see you have these in your siggy...
Dell Dimension 5150, P-4 2.8,ATI Radeon x700 256mb, 2 sata's 80gb 160gb 7200rpm, 1gb of ram baby!
Imac G4, 800mhz, 256 ram, 160 Hd
Emachines, Intel Celeron 2.4 512ram and 80gb drive
The Dimension would be ok but the emachines wont run that well with it disabled.
I thought you had to have 1.5 or 2GB of ram to really be safe with disabling your page file.
Hm, learn something new every day?
Well i have 1.2Gb of memory and its fine...Very fast with Page file disabled.
I don't think a blanket statement of saying yes or no can be made.
If you use Photoshop for instance it must have a page file to work, also many programs on startup automatically assign memory "just in case". You can see from this that a huge chunk of memory may be allocated and never used. I'd much rather it took virtual memory for allocation than my RAM.
So, if you have a lot of RAM, you don't need a pagefile, right? Not necessarily. When certain applications start, they allocate a huge amount of memory (hundreds of megabytes typically set aside in virtual memory) even though they might not use it. If no pagefile (i.e., virtual memory) is present, a memory-hogging application can quickly use a large chunk of RAM. Even worse, just a few such programs can bring a machine loaded with memory to a halt. Some applications (e.g., Adobe Photoshop) will display warnings on startup if no pagefile is present. My advice, therefore, is not to disable the pagefile, because Windows will move pages from RAM to the pagefile only when necessary. Furthermore, you gain no performance improvement by turning off the pagefile. To save disk space, you can set a small initial pagefile size (as little as 100MB) and set a high maximum size (e.g., 1GB) so that Windows can increase the size if needed. With 1GB of RAM under normal application loads, the pagefile would probably never need to grow.
thanks stanglehold. i use photoshop and after affects and flash and they use a lot of RAM and memory and i need as much as i can get. i dont think i'll be stopping it! thanks people!
