NewMonster
i jus ordered an OEM saphhire x850xt!!! for 111.00 US dollar grand total. is that a go0d deal?
and why is a x800xtPE superior than x850xt?
I have the x850xt I got for $90 ..the x850xt is superior to the x800xt pe the 850 uses a different core I think the 850 has 16 pipielines and the 800 only has 12..
Noob101....
The X850 does in fact use a different core than the X800 (R480 instead of the R423). However, they both have exactly the same stats, if clocked at the same speeds. They both have 16 pixelpipelines, etc.
http://www.gpureview.com/show_cards.php?card1=55&card2=41#
im thinking of getting one of those, what are the dimensions of it because i need to know if it can fit in my case? thanksi jus ordered an OEM saphhire x850xt!!! for 111.00 US dollar grand total. is that a go0d deal?
Noob101....
All PE means is that they use the same card as a non PE, and just slightly overclock it, no big deal.
uhh... jus wanted to say the link is a comparason of x850xt vs x800xt....
i wonder y x800xtPE has higher score in benchmark and higher spec than x850xt http://www.gpureview.com/show_cards.php?card1=55&card2=309
uhhh... i dont kno, i dont have my ruler but i can tell u that it fits my emachine mid tower 2005 T series
I meant to compare those two cards. The X850XT will perform better than the X800XT PE because of the higher clocks.
X800's have 16 pixel pipelines.
